Keyboard Shortcuts
The user can interact with SAInt-GUI by using keyboard shortcuts. Depending on the SAInt-GUI control element, e.g., the map window, the users can perform specific actions that save them time and let them work more efficiently. This section lists the available keyboard shortcuts in SAInt-GUI under their different control elements.
1. Ribbon Bar
The available keyboard shortcuts in the ribbon bar are related to the simulation and help tab as presented in Table 1.
Keyboard shortcut | Description |
F1 |
Access the documentation to the specific topic of the current control element. |
F5 |
Execute the active scenario. |
F6 |
Option to stop and exit a running simulation at the next possible time step. |
F7 |
Option to pause a running simulation at the next possible time step. |
F8 |
Option to continue a paused simulation. |
2. Dock Panel
The available keyboard shortcuts related to the dock panel (map window, script editor, command window, and property editor) are presented in Table 2, Table 3, and Table 4, respectively. In Table 2, the keyboard shortcuts act as a map selection filter in the map window. No keyboard shortcut is available for thermal objects at the moment.
Shift+select with mouse |
Select all objects. |
Shift+A+select with mouse |
Select only gas nodes. |
Shift+Q+select with mouse |
Select only electric nodes. |
Shift+S+select with mouse |
Select only gas pipes. |
Shift+W+select with mouse |
Select only electric lines. |
Shift+D+select with mouse |
Select only gas compressors. |
Shift+Z+select with mouse |
Select only gas control valves. |
Shift+X+select with mouse |
Select only gas valves. |
Shift+C+select with mouse |
Select only gas resistors. |
Shift+E+select with mouse |
Select only labels of all networks and hubs. |
Alt+drag and drop |
After selection, move selected objects |
Esc |
Unselect all objects. |
Ctrl+select with mouse |
Zoom into the selected area. |
click the middle mouse button or scroll |
Zoom to full view of all network objects. |
Ctrl+A |
Select All. |
Ctrl+Z |
Undo. |
Ctrl+Y |
Redo. |
Ctrl+C |
Copy. |
Ctrl+V |
Paste. |
Tab |
Autocomplete from popup suggestion. |
Home |
Navigate to the top of the list. |
End |
Navigate to the bottom of the list. |
Navigate through the list of elements upwards. |
Navigate through the list of elements downwards. |
Insert |
Add an element in a collection editor. |
Delete |
Remove an element in a collection editor. |
