1. Conclusion
Congratulations! You have just completed the first tutorial for making a hydraulic model in SAInt GUI. Through this experience, you have learned to represent a gas system with a network of nodes and lines and manipulate their position and properties. You also learned to create and define external objects attached to the nodes. Then, with the base model built, you learned how to set up a steady state and a dynamic simulation, define scenarios, integrate time-dependent data with profiles, and apply this data to objects to model the conditions of the system with events. Finally, you learned how to run the simulation and analyze the results with some of the features of SAInt. With this tutorial, you have built the foundation for which you will continue your journey to become an expert user of SAInt.
The next step in your journey is to learn how to use different features of the SAInt GUI to evaluate and visualize the results of the simulation and how to export data to be used as inputs for additional SAInt projects or post-processing.
