Step 4: Export Data
SAInt GUI has a range of export options that allow the user to extract network and scenario-related data. For scenarios, the stored results of an executed scenario can also be exported to various file formats (e.g., PDF, CSV, Excel, etc.). This tutorial focuses on exporting network and scenario data and also some base results using SAInt GUI export results option.
1. Network data
A network in SAInt can be exported to an Excel file. The exported file is used to edit any network object property or add/remove network objects. Once the changes are made, the exported network file can be imported back into SAInt using the Import  Network option from the network tab. You will first export the network from the first beginner tutorial to an Excel file. Start by opening the network GNET_Tutorial. Go to the network tab and click Export  To Network Import File  Gas Network Import File. When prompted to Select import file save location, navigate to your preferred location, type the filename, and press Save. Once the network file is exported, a message box notifies of the export status and location of the saved file, and the Excel file will be automatically opened.
Similarly, a network parameter file can be exported by clicking on Export  To Parameter Import File  To Gas Network Parameter Import File from the network tab. The parameter file contains the list of all the network objects with their respective property values, which can be changed. Once the property values are changed, the same file can be imported back into SAInt using the Import  Parameter option from the network tab. This action updates all the property values in the existing network.
The parameter import option for the network is only visible when no scenario is loaded into SAInt GUI.
2. Scenario data
The scenario related data, which includes results, events, profiles, network state, and state transfer events (dispatch and commitment), can be exported from SAInt GUI into different file formats. All the export functions for the scenario can be accessed by clicking on Export from the scenario tab. This section only focuses on the export of scenario results.
Please refer to the data export section of the reference guide for more information on exporting the network and scenario data and export file formats.
Once a scenario is executed, the stored results for a set of user-defined result variables can be exported to an Excel file. The result variables are defined in the Results Description File, which can either be a text, CSV, or an Excel file. The result variables are defined using the object parameter (ObjectType.ObjectName.PropertyExtension.[Unit]). Create a results description file to extract the active power generation of all the generators and the demand not served at the network level. Open a new Excel file and type the object identifiers in separate rows as shown in Table 1.
Table 1. Result description file.
GSUP.SUPPLY1.Q.[ksm3/h]
GDEM.DEMAND1.P.[bar-g]
GDEM.DEMAND1.Q.[ksm3/h]
After entering all the above object identifiers, save the results description file at your preferred location. Next, return to SAInt, go to the scenario tab, and click on Export  Results  From Gas Scenario. If the option is not available, just load the dynamic scenario of the beginner tutorial. When prompted to Choose Result Description File, select the previously saved excel file and press Open. Once the results description file is selected, another dialog box appears to Choose Result Output File. Go to your preferred location to save the results file and type the name of the output results file name. After pressing Save, a message box states that "Export all results may take a while to finish. Are you sure you want to continue?". Press Yes and wait for the results to be exported. Once all the results are exported, a message box notifies of the export status and the location of the results output file.
Click here to view the exported results file.
Time [sec] DateTime [dd/MM/yyyy HH:mm] GSUP.SUPPLY1.Q [ksmĀ³/h] GDEM.DEMAND1.P [bar-g] GDEM.DEMAND1.Q [ksmĀ³/h]
0
2/1/2020 6:00
200
34.97678796
100
900
2/1/2020 6:15
200.1328628
34.97446409
100
1800
2/1/2020 6:30
200.3851167
34.96968695
100
2700
2/1/2020 6:45
200.710031
34.96323646
100
3600
2/1/2020 7:00
201.0730794
34.95583293
100
4500
2/1/2020 7:15
202.1290641
34.87058808
101.25
5400
2/1/2020 7:30
203.5882987
34.76427993
102.5
6300
2/1/2020 7:45
205.2170454
34.64997009
103.75
7200
2/1/2020 8:00
206.9109442
34.53174033
105
8100
2/1/2020 8:15
208.0352436
34.49055938
105
9000
2/1/2020 8:30
208.8315781
34.4685847
105
9900
2/1/2020 8:45
209.4961627
34.45253966
105
10800
2/1/2020 9:00
210.1138133
34.43841599
105
11700
2/1/2020 9:15
210.684492
34.42547816
105
12600
2/1/2020 9:30
211.2210513
34.41334842
105
13500
2/1/2020 9:45
211.7376847
34.40170083
105
14400
2/1/2020 10:00
212.2438323
34.39030673
105
15300
2/1/2020 10:15
211.344486
34.5410988
102.5
16200
2/1/2020 10:30
209.5393911
34.73309111
100
17100
2/1/2020 10:45
207.3101288
34.93598822
97.5
18000
2/1/2020 11:00
204.8998369
35.13950994
95
18900
2/1/2020 11:15
203.7142994
35.19341652
95
19800
2/1/2020 11:30
203.2529369
35.21059664
95
20700
2/1/2020 11:45
203.0874685
35.21636015
95
21600
2/1/2020 12:00
203.0299037
35.21832215
95
22500
2/1/2020 12:15
202.8294396
35.15977751
96.25
23400
2/1/2020 12:30
202.2101324
35.09812197
97.5
24300
2/1/2020 12:45
201.2194997
35.04131357
98.75
25200
2/1/2020 13:00
199.9889921
34.98843659
100
26100
2/1/2020 13:15
198.7102993
35.00143105
100
27000
2/1/2020 13:30
197.668335
35.02118738
100
27900
2/1/2020 13:45
196.8600663
35.03822732
100
28800
2/1/2020 14:00
196.2015599
35.05227308
100
29700
2/1/2020 14:15
195.5893096
35.06501224
100
30600
2/1/2020 14:30
194.9864167
35.07733822
100
31500
2/1/2020 14:45
194.3839556
35.08955132
100
32400
2/1/2020 15:00
193.7805685
35.1017263
100
33300
2/1/2020 15:15
193.9961487
35.03484757
101.25
34200
2/1/2020 15:30
194.7231836
34.94542499
102.5
35100
2/1/2020 15:45
195.6808212
34.84709847
103.75
36000
2/1/2020 16:00
196.7334602
34.74448723
105
36900
2/1/2020 16:15
197.2735069
34.71715588
105
37800
2/1/2020 16:30
197.5381117
34.70753202
105
38700
2/1/2020 16:45
197.7031748
34.70292845
105
39600
2/1/2020 17:00
197.8377446
34.69978968
105
40500
2/1/2020 17:15
198.4278743
34.68906123
105
41400
2/1/2020 17:30
199.4114779
34.67021959
105
42300
2/1/2020 17:45
200.6230334
34.64591781
105
43200
2/1/2020 18:00
201.9485332
34.61852255
105
44100
2/1/2020 18:15
201.8737608
34.75040109
102.5
45000
2/1/2020 18:30
200.9125493
34.92201188
100
45900
2/1/2020 18:45
199.5493208
35.10396864
97.5
46800
2/1/2020 19:00
198.0208443
35.28654557
95
47700
2/1/2020 19:15
197.5284186
35.32446418
95
48600
2/1/2020 19:30
197.5659074
35.33031661
95
49500
2/1/2020 19:45
197.7755975
35.32777153
95
50400
2/1/2020 20:00
198.0272871
35.32307919
95
51300
2/1/2020 20:15
199.6638502
35.23159435
96.25
52200
2/1/2020 20:30
202.3075449
35.10761368
97.5
53100
2/1/2020 20:45
205.4793352
34.96713931
98.75
54000
2/1/2020 21:00
208.9009247
34.817308
100
54900
2/1/2020 21:15
211.0718113
34.75260284
100
55800
2/1/2020 21:30
212.2407149
34.72006643
100
56700
2/1/2020 21:45
212.8336441
34.70360033
100
57600
2/1/2020 22:00
213.1264443
34.69539343
100
58500
2/1/2020 22:15
213.268884
34.69136406
100
59400
2/1/2020 22:30
213.337504
34.68940885
100
60300
2/1/2020 22:45
213.370334
34.68846836
100
61200
2/1/2020 23:00
213.3859615
34.6880189
100
62100
2/1/2020 23:15
213.0345313
34.62865271
101.25
63000
2/1/2020 23:30
212.0536524
34.5701735
102.5
63900
2/1/2020 23:45
210.5417464
34.52034769
103.75
64800
2/2/2020
208.6835439
34.47715738
105
65700
2/2/2020 0:15
206.691207
34.50521448
105
66600
2/2/2020 0:30
204.8859511
34.5420503
105
67500
2/2/2020 0:45
203.2984752
34.57655634
105
68400
2/2/2020 1:00
201.8602648
34.60788056
105
69300
2/2/2020 1:15
200.3854715
34.63911303
105
70200
2/2/2020 1:30
198.8443071
34.67125785
105
71100
2/2/2020 1:45
197.2571296
34.70411996
105
72000
2/2/2020 2:00
195.6447847
34.73729892
105
72900
2/2/2020 2:15
193.3133878
34.91723016
102.5
73800
2/2/2020 2:30
190.7199321
35.12273204
100
74700
2/2/2020 2:45
188.1006308
35.32884744
97.5
75600
2/2/2020 3:00
185.509119
35.53004532
95
76500
2/2/2020 3:15
184.384338
35.58035108
95
77400
2/2/2020 3:30
184.0988472
35.59334625
95
78300
2/2/2020 3:45
184.1538623
35.59465919
95
79200
2/2/2020 4:00
184.3338367
35.59203958
95
80100
2/2/2020 4:15
185.7234641
35.50742895
96.25
81000
2/2/2020 4:30
187.8917118
35.39624987
97.5
81900
2/2/2020 4:45
190.4246925
35.27320498
98.75
82800
2/2/2020 5:00
193.112993
35.1439193
100
83700
2/2/2020 5:15
195.0090012
35.09043691
100
84600
2/2/2020 5:30
196.3964522
35.05774757
100
85500
2/2/2020 5:45
197.549945
35.03252761
100
86400
2/2/2020 6:00
198.6048781
35.01017745
100
